Faders [Tab 28]
The Faders display ([Tab] [2][8]) provides pages of virtual fader modules.
For information about configuring your faders, see Fader Configuration [Tab 36].
Faders Tab Configuration
Tab configuration menus contain additional sets of context-specific options for a display. They can be accessed from the bottom of the Tab Tools by right-clicking or double-tapping either the tab or the gear icon to the left of the frame's tab bar.
  • Layout
    • Rows - sets the number of rows used for the module. Maximum number of rows is six.
    • Columns - sets the number of columns used for the module. Maximum number of columns is six.
    • Show Main Fader Pair - check this box to display the virtual master fader pair. Unchecked by default.
    • Fader Display - check this box to display the virtual master fader pair. Unchecked by default.
  • Faders
    • Use Faders
    • Use Nudge Buttons - Modern style faders only. Toggles the triangular nudge buttons at the top and bottom of the virtual fader. Disabled by default.
    • Use Fader Ticks - Modern style faders only. Toggles the horizontal lines behind the virtual fader. Enabled by default.
  • Buttons
    • Use Load Button - toggles the load button above the fader. Enabled by default.
    • Use Button 2 - toggles the top button below the fader. Enabled by default.
    • Use Button 1 - toggles the bottom button below the fader. Enabled by default.
  • Control Buttons
    • Control Button Position
    • Use Arrows
    • Use Century Buttons
    • Page
    • Number of Page Buttons
    • Use Record
    • Use Jump To
    • {Jump To}
You can save your current settings as the default state for the tab. The current default is identified in parentheses.
  • {Reset to Default} - returns the settings to the default state that you created.
  • {Set Current as Default} - uses the current settings and tab number to create a new default state . The default tab will be shown in parentheses.
  • {Reset to Eos Default} - removes your saved default and returns all settings to the Eos defaults.
